adjust base cabinet height for finish floor
8/11/17
old bill Member
Can I use 1x3 pine boards around the base perimeter of the cabinet run to do this or should I use 3/4 inch plywood. This will be topped with 1 1/4 granite.
Thanks everyone,
Old Bill
8/12/17       #2: adjust base cabinet height for fini ...
eddie Member
Have the floor guys extend the floor so it will be under the cabinets. It's easier for them anyway. Especially eliminating all the cutting to fit where the appliances go.
8/12/17       #4: adjust base cabinet height for fini ...
old bill Member
I have to do the floor last.
8/12/17       #5: adjust base cabinet height for fini ...
Plywood has much better crush resistance than solid pine. Cabinet shops generally do not have solid pine on the shelf. The subfloor is plywood.
