Blown PC Nailers
4/16/19
Craig Caughlan Member
Website: wetimber.mx
Can anyone suggest why these two guns blew out within three days of each other? Pressure at 100 lbs. Different size nails. One happened during a misfire.
4/16/19       #2: Blown PC Nailers ...
They look well used.
Might you have had a spike in air pressure? Do you have a blow off valve that limits the top pressure?
We use Senco SLP20 and Omer micro pinners, bullet proof.
4/16/19       #3: Blown PC Nailers ...
mike
Are these oil or oil-less, hydraulic pressure is far more powerful than just air. Who is putting the few drops in them in the morning?
4/17/19       #4: Blown PC Nailers ...
Brad nailers,staplers, pinners should all be run 60-80 psi. Typically 65psi.
We hardly ever oil our guns. We have Hitachi trim guns that are 20years old which have done many mansions worth of nailing with a little drop of oil once a week in full use. We don’t want oil all over the trim. They aren’t framing guns.
I owned one of the PC pinners for years. The driver pin started leaving dents so we switched to Greg. I still own a PC 18 gauge stapler from the mid 2000’s that has fastened every cabinet back we’ve done.
The older PC guns were quite good.
4/17/19       #5: Blown PC Nailers ...
Both of them, 18 ga, were about 15 years old, and nothing lasts forever, but it was curious that they both blew a couple of days apart.
But I was noticing yesterday that the Dewalt pancake compressor that was serving them, surges; the air pressure is not even. So I think that was the cause.
I oil minimally, depending on the use. I had trouble with my Grex and Cadex pinners several years ago and learned that a drop a day is too much. No problems since I reduced.
4/17/19       #6: Blown PC Nailers ...
Snaglpuss
Must be common to these models.
We had two, vintage 2010, do the same thing.
We run ours off a rotary screw compressor- plenty of consistent air pressure, so your theory of fluctuating air pressure probably doesn't hold.
We got 9 years of hard use out of them, so I guess we got our money's worth.
New ones are pretty cheap now.
5/28/19       #7: Blown PC Nailers ...
Dan
They're old. They're worth 100.00. They don't owe you anything. Just get a new one.
