Using Vacuum Forming Table to Heat Bend Soild Surface
7/26/12
Dan Member
I know this is a bit unconventional, but we are trying to heat bend 1/2" Solid Surface with the heating elements from out Vacuum Forming machine.
Does anyone have any experience with this endeavor?
We are trying to dial in the temperature and time ratio. We only have a potentiometer for the heat so we can't determine the exact temperature. It's just been more of a trial and error approach.
8/1/12       #2: Using Vacuum Forming Table to Heat ...
Snaglpuss
We have a vacuum form with overhead heater too.
Our guy uses a laser thermometer and usually needs to do some samples to dail in the stuff.
Harbor Freight has them for $30 +/- so cost is not an issue anymore. BTW I have one of these at home and it works fine.
