Solid Surface European Mitre?
9/12/12
Dale Member
Have a "C" or "U" shaped solid surface top to make. All three sides are to be 30" deep. This leaves me with two inside corners. I am used to shallow tops utilizing an offset seam. I can only get 30" wide material, making that impossible. So can I use a European or dogleg mitre to join the corners? I am fairly confident that it would seam well enough, but the joint is still in the corner. A little stress may break it? Am I over thinking this? Any way to do corners on deep tops? Any advice is much appreciated.
9/18/12       #2: Solid Surface European Mitre? ...
Brian
Do a seam on the back side of the top
View higher quality, full size image (1106 X 806)
