Laminate Inlay Techniques
10/17/12
Don Member
I have attached a picture of some media stations and columns that I will soon be working on. They are to be inlayed plastic laminate. I am looking for advice on the best way to perform this. I will be using a CNC, and in the past I have just used a small diameter bit to cut the inside corners rather than squaring them off. It seems like there is always some sanding and trimming to make it fit though. How do you guys handle inlays like this?
EXAMPLE.pdf
