Removing veneer
11/2/12
Jim Member
Website: http://www.new-look-kitchen.com
Does anybody know how to easily remove veneer that has 3M Hi-performance adhesive on the back side? All I can count on is chipping it away in very small pieces with my chisel...
11/3/12       #2: Removing veneer ...
EDDIE
Try using a heat gun to soften the adhesive. Pulling up while heating.
Could get a serynge (spelling?) Fill with laq thinner. Have your veneer surface vertical. Peel a corner back and apply a little laq to the veneer. It will flow down eating the adhesive. Work slowly. Putting the laq on the veneer works easier than squirting it on the cabinet.
1/30/13       #3: Removing veneer ...
Jim Member
In case this information is helpful to others. While speaking with one of the chemists at 3M they told me that they named the product Hi-Performance adhesive because it can not be removed with heat or solvent. The bottom line was that it needs to be removed with a sharp chisel or something similar small pieces at a time..
1/30/13       #4: Removing veneer ...
Jim Member
In case this information is helpful to others as a follow up. While speaking with one of the chemists at 3M they told me that they named the product Hi-Performance adhesive because it can not be removed with heat or solvent. The bottom line was that it needs to be removed with a sharp chisel or something similar small pieces at a time..
