undermoutsink on SS
6/9/13
keith
Website: keithfarrlimited.com
Im doing my first undermount sink (not integrated) wondering if its more common to leave only 1/2" thickness or more common to build up the hole triple thick over the sink? Thanks for any advice
6/12/13       #2: undermoutsink on SS ...
Rob Member
We almost always just leave 1/2".... every no w and then we will build it up to 1"....
6/12/13       #3: undermoutsink on SS ...
keith
Website: http://keithfarrlimited.com
Thanks Rob, I'm also doing my first truly dark color, it's chocolate brown. I already know the sanding to a matte finish is going to be tough. Do you have a recommended sanding schedule for dark colors? Thanks for any help
6/26/13       #4: undermoutsink on SS ...
Dan Member
You have probably finished your counter top. Dark colors can be tough if you are not careful to go through the grits and clean in between. Look at you work in the light to see that you are removing the previous scratches completely. I like Mirca Abranet and Abralon products. I would try 150, 180, 240, 320 Abranet for matte and follow with 360 Abralon for a slight satin that looks good.
