Need glue suggestion to bent Laminate on alu ?
7/20/13
Robert Member
Need to bent laminate some Wilsonart Laminate on a curved aluminium pieces. I intend to use a vacuum bag system, but "blocked" over witch glue to use ??
Need a slow set open time glue as time is required to manipulate before "bagging" !?
Thks
7/24/13       #2: Need glue suggestion to bent Lamina ...
Tracy Kling  Member
Website: http://WWW.MANCRAFTINDUSTRIES.COM
scuff and use solvent based contact.
7/24/13       #3: Need glue suggestion to bent Lamina ...
Robert Member
Thanks for your reply Tracy, But.....
Vacuum lamination and contact cement is a guaranteed failure....is a no, no !
Need a glue with some slippage and....important....some little open time !
Again, thks for this though and suggestion !
7/24/13       #4: Need glue suggestion to bent Lamina ...
Tracy
Using contact you dont need to bag it just spray and stick. Scuff the alu and spray. We lay ip 4 x 8 sheets on radius wall panels never had one come loose.
