cleaning solid surface
11/12/13
Chris
I was working on a job I had to spray some polyurethane on some wall cabinets I didn't notice at the time but it setteled down on the solid surface top how is the best way to remove mineral spirits or some 400grit sand paper
11/13/13       #3: cleaning solid surface ...
Randy Member
Lacquer thinner, 400 grit sand paper will surely alter the sheen. You would have to sand the entire top.
11/22/13       #4: cleaning solid surface ...
Daniel K Member
I am probably to late on this reply. You can clean solid surface by several methods including a quick wiping with acetone with out effecting the sheen. It would be very easy to clean, depending on the finish sheen level with a scotch bright pad in gray or white with a small amount of denatured alcohol. If the poly was water based you could use any alcohol with a rag or paper towel. Solid surface is a fairly durable material.
1/9/14       #5: cleaning solid surface ...
Monday West Member
Perhaps lacquer would be enough for such stain but you may apply sand paper if the stain still persists. I also agree with the polyurethane solutions for removal of stains.
