Solid Surface Shop
4/22/14
I have the opportunity to do a job that could potentially last for a year, it entails me making 2 to 3 countertops per week. Having never done this type of work what would be the best setup to do this. I currently have a woodworking shop with all the standard shop tools and hand tools. Any websites that I should take a look at.
4/22/14       #2: Solid Surface Shop ...
Sam
One of many places to start try this site for special tool etc.
Pinske Edge
4/23/14       #3: Solid Surface Shop ...
scott
Check with the materials supplier if they will sell to you without their "certification". It may be required. Read the fabrication instructions on the sites from Corian and all the others. They get very detailed in choice of router, run speeds, saw blades and teeth etc.
A good table saw, good routers, straightedges, twice the number of spring clamps than you think you'll need, make a number of stands that fit under the counters, adhesive application gun, don't forget about skids and packing materials for shipping an shop carts for moving things around will be needed. Do not skimp on casters if you use them. It doesn't take much really.
Do you know how to set prices for your tops, did a big box store give you an opportunity and what they will pay?
4/23/14       #4: Solid Surface Shop ...
scott
Oh, forgot. The Pinske vacuum seaming blocks that level & pull the tops together are one "luxury" item that are defiantly worthwhile. Some other gadgets are nice but unnecessary or overkill or too costly.
The Festool saw and straight edge is good and keeps you off the table saw with the heavy materials. And a good buffer will make you finish work go easier and consistent, this after years of using palm sanders and scotchbrite pads - OK but slow.
4/23/14       #5: Solid Surface Shop ...
The job as of right now would be a labor only job. My customer, who is also a woodworking shop would supply any and all materials an I would fabricate the tops.
4/25/14       #6: Solid Surface Shop ...
If you were to set up your own solid surface shop from scratch what tools would you fill it with. I am talking about basic tools as well as more advanced tools. Also any special design for sawhorses that make fabrication easier, pictures would be appreciated.
