Cracked solid surface sink
5/1/14
Arvin Senne
I was the hired a solid surface to fabricate and install a solid surface top with integral sink last November I got a call from my client the dentist that his sink had a crack in it. The crack goes from left to right on the bottom of the sink. After sending solid surface shop a picture he immediately came to the conclusion some one had dropped something or poured very hot water in the sink.This means no manufacturing flaw and responsibility on their part. This is going to cost over $1000 to redo. It appears I will be in the middle on this one as no one says they were at fault. Any ideas on how to solve this and keep everyone happy. I feel I am least responsible for this problem but will have to pay for it
5/2/14       #2: Cracked solid surface sink ...
Alan F.
Call the rep for whatever brand material it is, they will make an unbiased judgment and tell you who has to pay for repairs if any. If its fabricator error they will force the fabricator to fix it or pay someone else to fix it, if its manufacturing error they will pay to replace it and if something happened that caused the damage that is outside the warranty they will let you know. Let them know the urgency of having a functioning sink in a dental office. They should have given you a warranty prior to being paid.
DuPont Corian® can be reached at 1-800-426-7426, you will need to Google the other bbrands
A-
5/8/14       #3: Cracked solid surface sink ...
Rod
When you do solid surface tell them there is no guaranty, only that you'll do your best. The material mfg can claim it's x y or z's fault the only way they will really warrant the material is if it's as delivered. We had a Corian factory molded (one piece sink and top) vanity top in the showroom not hooked up that the sink split and DuPont did replace, but we also had a Corian job go south - really nobody's fault.
The new kitchen spanned the joint (under the DW) between the old and new addition. There was a cast sink on one side and an Amana glass cooktop on the other. The first break was in the narrow edge @ the cooktop and actually had a noticeable shift. We repaired it. Several months later the glass cooktop literally exploded, they had a new cooktop installed WRONG then called me when there was a another crack. We fixed that and properly installed the new cooktop. Months later we get another call, crack at the DW this time I analyzed what was going on - the HOUSE WAS MOVING, the addition was settling causing the counter top to bend over the DW. I called the rep who looked at it and long story short said that DuPont can't be held accountable for house movement. Because I had told the customer that the top was "guarantied for 10 years" I ate it. We replaced about 14' of 'L' shaped top the addition had finished settling by then so there were no more problems. This earned me more work in the long run but did hurt in the short.
Moral of the story is - do not promise anything you are not willing to eat. Your business' long term future depends on your customer trusting you.
Your only hope in this situation is via the material manufacturer. The rep should be able to tell you what happen, if at all possible have the fabricator and the consumer there when the rep is there so you all can be on the same page. With the rep there you should be able to negotiate a more acceptable outcome.
5/13/14       #4: Cracked solid surface sink ...
I don't think corian warranties anything on commercial jobs. A quick fix would be to V out the crack and fill and sand. It will be somewhat noticeable though.
5/13/14       #5: Cracked solid surface sink ...
Alan F.
Corian warranties material only for commercial projects but if it is fabricator error they will tell them to fix it.
A-
DUPONT™ CORIAN® COMMERCIAL (PRODUCT ONLY
9/13/16       #6: Cracked solid surface sink ...
MiguelWashin Member
Hey, thank you for the question. I totally agree with Rod's concept and views. You must go for it and get it appropriate and clear. All the best!
