laminate substrates
6/2/14
marci
Website: http://iconifyliving.com
I am in the process of designing a high end modular furniture line and am looking for the best substrate for laminates sliding panels that need to be 1/4 inch thick. a 1 inch finger hole and edging need to be finished for decorative purposes. Any thoughts?
iconify_skate.pdf
6/3/14       #2: laminate substrates ...
Dave Edgerton  Member
Yup, solid phenolic bonded with laminate faces. Try formica. they have 1/4 inch and up.
6/3/14       #3: laminate substrates ...
marci
would solid phenolic fray over time siding in a powder coated aluminum track? the panel will be 12 inch ht x 19 inch long
6/3/14       #4: laminate substrates ...
very tough stuff. I doubt it would show any wear at all.
Formica Compact
6/5/14       #5: laminate substrates ...
Misty
Website: http://www.coolwoodworkingplans.com
Over 16,000 clear, detailed, accurate and easy to follow woodwork diagrams for almost any woodwork project you can imagine. A 200 page Woodworking Guide with many methods and techniques you can use on many projects.
6/9/14       #6: laminate substrates ...
Bruce H
Bet your "high end modular furniture line " won't have the budget for a phenolic product. You might try using MDF, based on the size it should not be a problem.
6/26/14       #7: laminate substrates ...
marci
thanks for the feedback
