Removing laminate
6/3/14
Chris Member
I have a problem, I am laying up some laminate and I have some bumps in a couple of pieces. I have tried the idea of trying to slide a flat piece of metal in between the surfaces to remove the bumps. That did not work for me, so I think I need to remove the sheet. I have done this before while a solvent base adhesive. But I am using Hybond hy-31n which is a waterbase and I need to know how to remove the sheet and what to use to clean up the mess. Thanks in advance.
6/4/14       #3: Removing laminate ...
Dave Edgerton  Member
Laquer thinner should break the bond. Turn the sheet so that you can pour a bit in between the lam and substrated and allow the thinner to flow downhill between them. Should peel right off. Keep adding as you go
