Linoleum counter tops
12/2/14
Does any one have any experience with linoleum counter and table tops?
A client has asked me to make some table tops with linoleum and info seems to be scarce.
12/2/14       #2: Linoleum counter tops ...
Alan F.
There is linoleum made for tops, sold 2 yard wide by length. I haven't worked with it in years but we did a lot of cash wraps over the years with linoleum tops and metal edges. A lot of the laminate suppliers that carry flooring would have it.
Just stick it trim it and your done.
Forbo Marmoleum
1/4/15       #3: Linoleum counter tops ...
Gavin Member
I was part of a job about a year ago which consisted of of a long serpentine service counter topped with 'marmoleum', which is just a brand-name of linoleum. This stuff was about 1/8" thick. We applied it with spray-on contact adhesive, just like laminate, but went a little heavier than usual with the adhesive, because the backing is more textured - almost like woven jute fiber. It was actually very forgiving and seemed to stick down fine. It could be routed, scraped and sanded with good results. It didn't seem to require any special techniques.
One point to note: we routed a small chamfer in the top layer of the marmoleum, and the solid wood edging had a matching chamfer, creating a small 'v' shaped shadow joint. I believe this was to protect the edge from being pried up or catching on something. The designer seemed to have worked with the marmoleum before, so maybe this is a precaution specific to linoleum, but it's possible it was just for aesthetics.
