edge banding 1 1/2" strips & clean up
1/13/15
Steve Member
we are using outsourced parts 1/2" melamine pvc edge banded ? 1 is it possible / reasonable to run 1 1/2" inch x 81/2" strips
? 2 we are getting quite a bit of glue is that normal, also what is the best product to clean adhesive with, thinner and solvent are not cutting very well
thank you for your help
1/13/15       #2: edge banding 1 1/2" strips &am ...
Alan F.
1.5 x 8.5 is too small for a lot of edge banders, if you are doing all 4 edges something may need to be hand edged. Otherwise if its the 8.5" edge then run 3-1/8" pieces, edge both then rip and cut.
A-
