Cracking on 6" walnut post glue-ups
3/12/15
Scott Spiess Member
Anyone with experience doing really thick solid hardwood glue-ups? (6")
We recently made 8 large walnut beds with posts that start at 6" thick before machining on CNC 4th axis. We had 3 or 4 of the 32 posts develop long cracks afterward. We glued up 7 layers of 4/4 stock. Some of these posts had been glued up for 3-4 months (project delay) before machining. 3 of the 4 posts that cracked developed the cracks shortly after machining. We used normal Franklin EZ2 glue for the glue ups. The cracks were long and with the grain, occasionally partially on the glue line but usually not.
My guess is that with 7 layers the glue introduced a lot of water into the post - the cracks occurred due to the water in the glue causing the wood to expand.
I think polyurethane glue would be a better choice next time - any other thoughts? Other glues?
