curved edgebander reviews
4/19/15
Randy Member
Website: http://creativesignsnmore.com
I am looking to purchase a edge bander that does curves, with a budget of $4,000 to $6,000 does anyone have any comments on a brand? or a brand you would recommend? I really don't know what to look for in good and bad specs. Any thoughts would be appreciated.
5/6/15       #3: curved edgebander reviews ...
Dan  Member
Website: http://www.stgermaincabinets.com
We just had a Festool rep in our shop to demo their "Conturo" contour edgebander. It was impressive on large radius (4" and up), but on a 2" radius, the banding popped away. It came in at about 17lbs. which isn't too bad, unless your running it all day. Also the banding needs to be cut just a couple inches longer than needed... just a few things to consider...
5/6/15       #4: curved edgebander reviews ...
Randy Member
Dan,
Thanks for the info! My parts are 1.5" radius and ends right after the radius. I see Laguna has staionary one and I am going to check theirs out. I have a Laguna Smatshop1 CNC and am really happy it. Solid and very well built.
4/11/16       #5: curved edgebander reviews ...
Benjamin Member
Does anyone know if the Contura can handle a tight inside radius of 15mm on the inside of an L shaped shelf? It seems that the pressure wheel supplied is bigger than that, but I would love to stand corrected.
Another concern, since all the bonding pressure is from the operator, how good is the bond? Or is the glue different so as to achieve a bond with minimal pressure perhaps?
4/11/16       #6: curved edgebander reviews ...
Randy Member
I ended up purchasing the Festool Conturo. The diameter of the pressure wheel is 1.5" so 3/4" (19MM) would be smallest radi.
I have had no problems or complaints with it. I have only used colored banding for melamine. The 1mm thickness seems to work the best. I tried using .5mm and the sub surface tends to show thru.
I haven't had any problems with it not sticking due to minimal of pressure. I mainly use the Festool table with it. I have probably put on about 2,000 ft.
4/12/16       #7: curved edgebander reviews ...
Benjamin Member
Thanks for this info Randy.
