high gloss white laminate with matching edgebanding - glue questions
5/1/15
antonio
Website: http://positivewoodworks.com
Ok, so got this job to do a italian style 'high gloss white lacquer look'. Decided to try out this system from dixieply using a product of theirs called acrylux. Problem is, the only way we know to apply both the laminate & edges are with contact cement, by spraying it on, here are our problems: (we are using mdf substrate)
1 . The panels seem to look dimpled, not quite like there are grains of sand stuck on the substrate, but more like maybe the unevenness of the sprayed on contact cement is transferring through? How do you create an even surface spraying on contact?
2. The glue line between the edge banding and laminate face is kind of obvious how do you minimize this?
5/2/15       #2: high gloss white laminate with matc ...
Nick
Hey Antonio,
You can lay up the laminate in a press with a "firm" glue line to fix the problem of the contact telegraphing through.
As far as the glue line, you can laminate the face last so it's on the edges and not as visible, but quite a bit more time consuming.
I've found that you're better off going to white vinyl wrap (which has more of an "orange peel" finish) if they're on a budget, or just spraying them gloss white. I've had fantastic results with automotive finishes on mdf, and at the end of the day not that much more expensive.
5/4/15       #3: high gloss white laminate with matc ...
I'm just so darned curious. How could you bid the job with no experience with the material or process? Do they make a thicker grade of laminate?
5/4/15       #4: high gloss white laminate with matc ...
antonio
Because, Rich, in this business there are projects that come up that are seemingly very similar to other successfully completed projects, so we go into it with the experience we do have, and, with every other job we always have a bit of cash allowance in it for the unexpected. In every job i price, there is always an exit strategy , a plan b or c. Sure, it may dip into my profit a bit but eventually the job always gets done well.
5/8/15       #5: high gloss white laminate with matc ...
Alan F.
Antonio,
The kitchens people are seeing using this material are being edged on laser no glue line edgebanders. Rehau offer cut to size edged parts, not sure if they ship to your location. There is a company in Denver doing cut and edged to size with the acrylics. They also layup the panels.
REHAU Introduces High-gloss Surfaces to
5/8/15       #6: high gloss white laminate with matc ...
antonio
thanks alan, i discovered that recently as well about the laser edging, but i also heard (not sure how true it is) that in our part of the woods (the bahamas) laser edging does not hold up due to heat/humidity. I spoke to a company that is sending me samples so may go that route for future jobs that involve kitchens, but this particular job being a laundry room (yes they want shiny doors in their laundry room LOL ) i think i can get away with sticking on the edgebanding if i can get a hold of some white contact cement that matches the banding. Looking into it :)
5/8/15       #7: high gloss white laminate with matc ...
cabinetmaker
we use clear contact cement for jobs that we can't run through the edgebander. Sometimes we see the exact same thing when we use fire rated core and have to lay up panels for a hospital job, its amazing that what we notice is not really noticeable once it hits the field- serious.
Rolled on cold press glue and pinch roller or for something with 5 or 6 doors, yellow glue and a hand roller ladet it set up overnight with a few sheets on the layups for weight
5/9/15       #8: high gloss white laminate with matc ...
antonio
which clear contact cement do you use?
5/29/15       #9: high gloss white laminate with matc ...
hardwoodfloor  Member
Website: http://hardwoodfloorsrefinished.com/
You can lay up the laminate in a press with a "firm" glue line to fix the problem of the contact telegraphing through. You can laminate the face last so it's on the edges and not as visible, but quite a bit more time consuming.
