pvc edgebanding with wilsonart h2o contact cement
5/5/15
antonio
any of you guys used wilsonart h2o water based contact cement to bond pvc edgebanding to mdf?
5/6/15       #2: pvc edgebanding with wilsonart h2o ...
Robert Member
Wilosonart H2O is not recommended for non-porous applications like PVC edge banding. Your success may be limited and it may not last.
Sorry...
5/6/15       #3: pvc edgebanding with wilsonart h2o ...
Robert Member
Another thought have you contacted you local Wilsonart sales person. They may have other material like the Wilsonart M glue that is for one non-porous to a wood substrate.
5/6/15       #4: pvc edgebanding with wilsonart h2o ...
antonio
thanks robert, yeah i did speak to them and they said due to the material possibly having plasticizers in it that it probably wont work,,, i know of a lot of alternatives that will work but this is for white edgebanding to mdf that is laminated with white acrylic sheets so i dont want the yellow line that regular contact cement leaves which is why i was going to try the h20 because apparently its white.
5/6/15       #5: pvc edgebanding with wilsonart h2o ...
Robert Member
I never heard of a plasticizer having any issues with Wilsonart's Melamine glue or any melamine glue. The label states vinyls, plastics, and other non porous material. Melamine glue dries clear. I would try calling the 800 number on the back of the Wilsonart laminate chip and ask to speak with someone in adhesives. Good Luck hope it works out.
6/1/15       #6: pvc edgebanding with wilsonart h2o ...
hardwoodfloor  Member
Website: http://hardwoodfloorsrefinished.com/
You May contacted you local Wilsonart sales person. H2O is not recommended for non-porous applications like PVC edge banding.
