Bubbling of laminate on semi-solid core doors
7/16/15
Ed Pionkowski Member
Website: http://islandfurnitureltd.net
I have a first. After making a series of doors for a recent project covered with a no name laminate glued with our usual contact adhesive and hardwood lipped, all of the laminate on both sides of the doors has bubbled in large (8" to 12" bubbles and lots of smaller ones. Laminate is glued to 1/4" perfectly dry US sourced plywood from our usual supplier.
I queried the distributor of the contact cement who sent a rep to check the lot numbers on the cans and they reported that this had never happened to them and that the batches were different and could not possibly all be bad - three batch numbers on 8 gallons of glue. We then removed the laminate carefully using thin laminate wedges and lacquer thinner as there was no more of the particular color specified available (we are on an island and import everything). We cleaned off the old glue as best we could and then re-glued using another brand of contact cement. We re- lipped the doors with the same mahogany but noticed that the laminate had "grown" by about 1/16" and had to be edge trimmed flush again. 5 days later the laminate had bubbled in exactly the same way. In 25 years of using laminates ( not our specialty, but it's not high science) we have never seen this happen. I can only assume that this is a fault in the laminate. Any thoughts on this?
By the way - the doors are for the supplier of the laminate.
