thermoform solid surface
11/18/15
Matthew Thomas
I will be buying an oven for an upcoming job with 3" radius edges. I read a few of the posts on this site, but I'm still unclear on the overall process. After the edges are heated up, then what? Do they have to be vacuum pressed to a form? Or can I directly attach the heated pieces to my counter? And how do the heated (or formed) edge pieces attach to the counter? Do you rabbet the bottom side of the counter 1/2" in order to index the formed pieces to it? Or just butt it to the counter, glue and clamp?
Thanks.
11/19/15       #2: thermoform solid surface ...
Damir Dehlic  Member
Hello
You need to let the heated piece cool down before you can glue it to the counter top.
After you heat the piece putt it on a mold to cool so you have a desired radius.
Then you need to make a strait edge on that piece so you can glue it to the counter top. You can butt it to the counter top if the color of solid surface is white or some solid color.
If solid surface is similar to stone you will probably need to make a rabbet going almost all the way thru the counter top living just 2mm of material and then glue the buildup.
Damir Dehlic
11/19/15       #3: thermoform solid surface ...
Matthew Thomas
Thanks Damir.
Making the rabbet with just 2mm remaining is because the counter edge won't match up in color to the face of the formed edge?
11/19/15       #4: thermoform solid surface ...
Damir Dehlic  Member
Yes some colors aren't uniform so you will need to make a rabbet living just 2 mm or making a miter joint.
I attached a pdf with instructions for Krion (page 67) but You need to make a sample and see if the butt joint is OK.
Fabricator_Manual_2014.pdf
11/19/15       #5: thermoform solid surface ...
Matthew Thomas
Thanks.
The section on doing the thermoforming is helpful. The section about how to apply the thermoformed piece to the top is a bit lacking.
I'm excited to start baking plastic!
