How to clean panels prior to lamination
12/11/15
Kyle
We currently use MDF as a substrate and press our HPL using a vacuum bag using standard PVA adhesive. I am having some difficulty not getting rejected panels from debris. Many panels come out ok but there is almost always a panel or two that doesn't make it. We do small highly custom runs for conference tables. Anywhere from 2 to maybe 10 panels. Since they are table tops even the smallest defect is rejected. Are there panel cleaning machines that I could look into. Right now we are just using compressed air and wiping the panel until no debris is felt anymore. Thanks for your input
12/12/15       #2: How to clean panels prior to lamina ...
I would recommend you install a fluorescent fixture near table height by your glue up area. Get down and look at the glue surface with light reflection and you will be able to pick out the crud. Also much of the dust dropping onto my glue and finish was from my clothes. Consider a lab coat kept in a clean area.
12/12/15       #3: How to clean panels prior to lamina ...
david
Kyle,
There are feed through panel cleaners that are on the market.... I fought for one at the start of my automated hot press line for years.
While I was fighting, we used a simple dust brush (think old drafting brush) to dust off the face surface of the panel. It seems sort of simple, but it worked until we bought and installed the panel cleaner in line with our operation.
