advise on how to laminate a 25x156 wood top
1/28/16
Robert  Member
Seeking for advise on how to…..(steps)…. approach on making a commission 13foot by 25inches edge grain countertop top…..when one only have a 20 plainer and no clamping rack ??
Also, I’m quite concern on the how to glue it all up within the glue ( titebond-3) open time even if it’s quite long ( +/- 15-20min) ?? ( I don’t have a clamping rack…..but lotss of clamps !!)
All the necessary wood needed to make such a pieces ( 25 x 156”) appears to me, not just intimidating, although I’ve been making woodworking for a living for over 15yrs, I’ve never had to make such a long (multi segmented) lamination….. as a challenge I’ve never had to face before.
Any suggestion from one who has actually done some would be very appreciated !
Thanks, Robert
2/5/16       #2: advise on how to laminate a 25x156 ...
JimHerron
I don't have a wide planer now, though I did have a 24" x 8" at one time. I do have a 36" widebelt.
I would glue it up in two pieces that will individually go thru your planer, then do some dowels to register those sections together, and do my final glue joint.
Then scrape it or find someone local to widebelt it. The last joint should clean up fairly easily if registered to each other closely.
Just prep your strips plus some extra before starting any glue up.
2/6/16       #3: advise on how to laminate a 25x156 ...
Robert
Thks Jim !!
