Filing edges on laminate
3/23/16
Tina Thomas  Member
Website: http://www.museumfg.com
We are having an internal disagreement on the best way to file the edges of laminate cabinet door.
Please post your method....long strokes in one direction or back and forth.
3/24/16       #2: Filing edges on laminate ...
Chip Geffre
Hi Tina-For self-edge laminate I was taught that the file is to be used in forward strokes without dragging the file backwards. That being said, you might try a sharpened steel wood scraper and scrape or "scarf" the length of the laminate.
This method will remove the laminate in shavings and will produce a really nice edge. I have also used a file much in the same manner.
Best Regards,
Chip
3/25/16       #3: Filing edges on laminate ...
Chris
Website: http://www.hofmannjoinery.com
Lamello makes a nice little laminate trimmer with a horseshoe base so you're not riding up on the edge of the laminate in front of the cutter like regular machines.
Lamello Laminate Trimmer
4/10/16       #4: Filing edges on laminate ...
You do realize the file only cuts in one direction?
The key is to do as little filing as possible.
