color core laminate & edging
6/8/16
antonio
Website: http://www.positivewoodworks.com
For you guys that are familiar with color core laminate (formica brand or other) my questions are as follows:
Are you using a matching edgebanding or just ripping strips of the same laminate to use as edging?
Im sure on darker colors it wont show as much but for the white color core if you are using the same laminate as the edging what type of adhesive are you using to decrease the glue line ?
6/13/16       #2: color core laminate & edging ...
Bruce H
clear contact cement.
6/13/16       #3: color core laminate & edging ...
antonio
Thanks that's what I thought but all I can find is wilsonart 700 which is white but dries clear but it only comes in a small aerosol so will get to be expensive. Which product do u use bruce
6/13/16       #4: color core laminate & edging ...
Bruce H
I buy spray grade Formica adhesive (clear) in five gallon buckets. Using a conventional pressure pot and Binks spray gun with a large tip.
