laminate seam in front of kitchen faucet damaged by water
11/14/16
GoHawks Member
Is it possible to reglue the damage? The sink base is now barely sitting on that area and is sinking down. Underneath the sink I can see the builder did a lousy cut out for the sink and can see a gap. The backflash is a separate piece.
11/14/16       #2: laminate seam in front of kitchen f ...
eddie
Looking at the waves in the top. The particle board is trash. Rip the top out replace it.
When you do that: put a small continuous bead of silicone around the sink hole. This will help keep water out. Then set the sink. Caulk the back splash to the top. From the picture it appears no or little caulk at the joint. If you redo the bar top. Laminate the bottom of the bar top. You can see the particle board coming apart behind the sink.
12/6/16       #3: laminate seam in front of kitchen f ...
Bruce H
The sink cut out is the WRONG size. Make the contractor come back and fix it. There is no other way except living with the issue.
