Finger jointing cutter specs
8/21/18
Morné Crouse Member
Good day all
Please assist, we are working with wild growing Gum and Poplar in South Africa, what will the best specs for finger joint cutters to use on this timber? (hard and softwood), especially the finger length.
What would also be the recommended glue to be used.
8/21/18       #2: Finger jointing cutter specs ...
matt
If the gum tree that you are growing is an American species, you're likely to have difficulty getting it to mill and cure properly.
Gum tends to have a significant amount of warp and isn't used much for cabinetry. Especially if this is "Sweet Gum", which is one of the most frustrating trees to ever grow out of dirt.
