Sawing and Drying
Subject:
WoodMaxx bandsaw blades
1/2/14
Dave Miller Member
Has anyone had any experience using Kasco SharpTech - WoodMaxx bandsaw blades ? I see they are made in the USA & the price seems to be good.
1/4/14       #2: WoodMaxx bandsaw blades ...
Tom the Sawyer  Member
Website: http://www.TomTheSawyer.net
Dave,
I got a couple of their 7 degree blades to try. One hit a nail pretty quickly but the other milled about 1100 bf of sycamore without slowing down noticeably. Both re-sharpened fine. I wanted to order some of their 10 degree blades to try but, although the prices were pretty good, the minimum order was 15 blades of each hook angle. Maybe later this year...
1/20/14       #3: WoodMaxx bandsaw blades ...
Dave Member
Tom....The sales rep contacted me & is sending a 7&10 degree hook blade for trial. He indicated that they would be willing to mix the blades so you did not have to order 15 of each. Once I get the blades I will give them a run for the money & advise.
2/10/14       #4: WoodMaxx bandsaw blades ...
Dave M Member
Got the samples & they cut really well. Am going to place an order. Sales rep said if you wish to buy a "mixed" box, it may take up to 2-weeks to receive the order.
3/1/14       #5: WoodMaxx bandsaw blades ...
Steve Member
Received my first box in November,late fall, only had time to use one before this cold wet weather set in. I found it to cut as well any blade I have used on my LT40 woodmizer.
6/8/14       #6: WoodMaxx bandsaw blades ...
DaveM Member
Weather here finally dried up enough to get the mill out & saw a bit. The blades cut as good as any & maybe a bit better than others. A 21" locust cut like butter & a large beech was no problem. 7' seemed better on the locust, but not a lot of difference between the 7" & 10'.
6/8/14       #7: WoodMaxx bandsaw blades ...
DaveM Member
I should add that I only tried the blades earlier this year. This time I actually got to give them a decent workout.
