Sawing and Drying
Subject:
Drying bookmatched walnut slabs with 50 bullets cut in half.
1/12/14
Logs To Lumber
Website: http://www.logs-to-lumber.com/
Check out these book matched curly walnut slabs from a tree I logged down near Cannon Falls Minnesota. They are 2"x 44"x 80" long. I was nervous because this tree was 20 yards away from a deer hunters tree stand. I wondered if it had bullets in it, but nothing like this. These are the first two slabs off the log and I cut through 50 bullets.
So I'm thinking with 6-8% shrinkage across the face, will that pop out the bullets, which I want to leave for effect.
Would any kind of coating besides anchorseal help hold them from popping? How would you guys handle it?
View higher quality, full size image (943 X 1529)
Facebook post
1/12/14       #2: Drying bookmatched walnut slabs wit ...
ESL
I have never had a slug pop out of a piece of wood - they stay put.
1/12/14       #3: Drying bookmatched walnut slabs wit ...
Tennessee Tim
I like those slabs....unique!!! 6-8% shrinkage???? that would be approx 1.32"-1.76" each board there or 2.64-3.52" total.....I don't think I've every lost that much in shrinkage??? Sounds like a lot!!!
I heard of some logs coming off an army base full of steel jacket bullets....HIT the Deck!!! shrapnel flew everywhere!!!
Here's how close I got one time.... sliced so close I couldn't figure out what was shining!!! possibly 357 mag
1/13/14       #4: Drying bookmatched walnut slabs wit ...
Keith Newton
I and a lot of turners use Thin Cyanoacrylate , or CA, or Superglue for situations like this.
However it is accelerated by moisture, so it would be best to wait until after it has dried, but probably before planing to use it. The thin, or fast, will run into any thin crack in the torn fiber of the wood that the bullet made going in. It then sets up as a hard plastic.
It is a little tricky to learn to use it. And it can set so fast, as to generate enough heat to smoke. You really want to avoid breathing the smoke, or even smelling it as it evaporates.
The trick is learning how to tip the bottle, and slowly let it flow in for as long as it will take it. If you do a little, then try to come back after the first dried, it will seal out the second try.
You can usually find it in good hobby stores locally, or order it online.
1/21/14       #5: Drying bookmatched walnut slabs wit ...
Dave Boyt
No advice, just admiration. Nice pieces.
