Sawing and Drying
Subject:
Drying Pine
1/25/14
dlahart Member
How do i keep the mold out of fresh cut pine being air dried?
1/26/14       #2: Drying Pine ...
Gene Wengert-Wood Doc
Dry it quickly...lots of air when the RH is,under 90% RH.
1/27/14       #3: Drying Pine ...
dlahart Member
Gene, that does't seem to work.
In NW Florida. I keep Fans on the lumber 24/7.Any other advice you have will help.
Just getting started, not a lot of cash on hand!
1/27/14       #5: Drying Pine ...
Gene Wengert-WoodDoc
Do not run the fans when the humidity is over 90% RH.
1/28/14       #6: Drying Pine ...
Dlahart Member
Why, what will happen?
Tell me about humidity and fans"
Thanks, always trying to learn
1/29/14       #7: Drying Pine ...
Dca you check the info on temperature, humidity and velocity in DRYING HARDWOOD LUMBER? It applies to softwoods exactly the same.
That book is on line here at WoodWeb.
Also,, the past few issues of Sawmill and Woodlot magazine has a series on white pine drying that applies to you as well.
1/29/14       #8: Drying Pine ...
Dlahart Member
Rodger that
I appreciate the info sir
