Sawing and Drying
Subject:
controlling the humidity in kilns
2/7/14
Artie
Website: http://www.bigtimberinc.com
I have been operating the kilns for about a year. this past winter I have noticed the actual depression in the kilns is greater than what I have set the temps. We have tried to add steam to the kilns from our boiler. We have 4 50k kilns filled with white oak and red oak. When we had just 1 kiln with red oak in it I was able to add steam and keep the depression where I needed it. Do I need to add more boilers to adding steam? Is this a common problem with older kilns?
2/7/14       #2: controlling the humidity in kilns ...
Gene Wengert-Wood Doc
In this colder weather, it is not uncommon to find that the floor or other area without good insulation is cold...maybe 80 or 85 F. So, now when the wet-bulb wants to get higher than this "cold" spot, the moisture condenses at this spot. Sometimes this cold spot can be vent covers This cold spot acts like a dehumidifier. So, you can add a lot of steam to get the WB up. Of course, fixing any cold spots is also an option, but it may take some warmer weather. The third option is to lower the DB until the correct depression is achieved.
In the short term, you should turn off the fans to let the lumber rest if it has been drying at the larger than desired depression. If the fans are off, you do need to be aware that pipes can potentially freeze in this cold weather when the steam is off...many kilns have a freeze setting that allows steam flow at all times.
