Sawing and Drying
Subject:
Second Log I've Cut with my Bandsawmill
2/20/14
rod hays
Here's a video of the second log I've cut up. I had to do a little adjustment at the beginning, and now it's working beyond my expectations. A little bit more practice and I'll be running it a lot more efficiently.
2/25/14       #2: Second Log I've Cut with my Bandsaw ...
Dave Boyt  Member
Very nice, consistent cutting. I've always been skeptical about using tires for bandwheels, but you've shown how well it works. I kept waiting for you to cut into the clamp. Guess I'll have to wait a little longer.
2/25/14       #3: Second Log I've Cut with my Bandsaw ...
Rod Hays
I wasn't sure if using those big 27'' tires would work. Those wheels are 50 pounds each. I figure the weight of those heavy wheels would give inertia for cutting,which I believe it has.The video shows the blade cutting the wood like hot knife through butter. Also what I like about using tires is I don't need to have water running on the blade to cut.
3/3/14       #4: Second Log I've Cut with my Bandsaw ...
Rod Hays
Went up into the woods Sunday and cut down a popular along the side of the road that was in the way, and not a very good tree. Here is a video of one of the logs from that tree on the mill. It was about 36'' wide at the widest part of the log.
3/3/14       #5: Second Log I've Cut with my Bandsaw ...
Rod Hays
Here is a video of what the curved boards look like off that popular log from the video above.
3/5/14       #6: Second Log I've Cut with my Bandsaw ...
The only thing that jumps out to me, and Im not sure Im seeng clearly in the video, is it looks like your bunks may be very light and I would fear over time they are just not going to hold up. But again, may be seeing incorrectly in the video.
In my experience rolling logs on a mill over time is absolutely brutal. Members twice as robust as you would normally think will be bent and distorted in just a short time of sawing.
Nice though all in all. Likely a very rewarding project.
The task at hand now is working on the "sawyer" part. Learning to read your logs, cut tension out of a log, and get the best possible boards you can out of each log because home built mill or not, if you apply $5/hour to your time, these will be some of the most expensive boards you will ever lay your hands on. So better make sure they are as nice as possible.
When you see board springing off the cant as your sawing them you know they are going to get worse each minute that passes.
3/5/14       #7: Second Log I've Cut with my Bandsaw ...
Dave Boyt  Member
I go along with beefing up the cross members, maybe using square tubing. The main thing I see is that the cut appears to be smooth and straight. You sawed it exactly the way I would have, which is the curve flat on the track, and leaving both edges natural. I looks like that piece might have been from a branch-- or from a very crooked tree. Either way, it would have a lot of stress. When you get cutting straight logs, you'll be amazed at how much more satisfied you'll be with the mill. Those slabs have good potential for a counter top, bench, or table.
3/7/14       #8: Second Log I've Cut with my Bandsaw ...
Rod Hays
I agree the cross members are a little weak,but they were what was laying around so I used them. I'll more then likely replace them with something stronger. Someone wanted to see a better video of how I built the bandsaw mill,so I hope this video helps. If not I'll make another one on what I didn't explain in this one very well.
3/7/14       #9: Second Log I've Cut with my Bandsaw ...
Rod Hays
I made a video of cutting up the oak log. I'm stating to get use to the sawmill and the problems I might run into. Haven't cut any metal with the saw blade yet.
3/7/14       #10: Second Log I've Cut with my Bandsaw ...
Rod Hays
Made a sawdust deflector and it seems to have helped. I made this video cutting the other part of the tree limb with the sawdust deflector.
