Sawing and Drying
Subject:
Sanding Beech
5/15/14
Rod Hays
I sanded this Beech and it looks really nice. I'm planning on using Pentacryl Wood Stabilizer to keep it from checking. My plan is o just rub the Pentacryl on from time to time as the water evaporates.
https://www.youtube.com/watch?v=5mMwRaJPG8g
5/17/14       #2: Sanding Beech ...
Gene Wengert-Wood Doc
Beech is not prone to checking, like oak is. So, with proper drying, you do not need a chemical treatment.
I am curious if The chemical you mention can be or is applied by just rubbing it in from time to time. I have always seen the wood being soaked in it, which means it was used on smaller pieces. It is too expensive to use on lumber.
5/17/14       #3: Sanding Beech ...
Rod Hays
Thanks Gene,I didn't know that.
5/18/14       #4: Sanding Beech ...
Rod Hays
here is what beech looks like sanded with some sand and seal on it.
View higher quality, full size image (600 X 337)
