Sawing and Drying
Subject:
Steaming/stickering questions
9/19/14
10Goal Member
Hi folks, first post in a long, long time. I'm looking at putting together a small-scale, black walnut (only) milling and drying operation, with possible steaming. I believe I've read all the posts regarding steaming, but I still have questions:
Everything I've read tells me to tight-stack the lumber for steaming, then sticker it to dry it.
Why must the lumber be tight-stacked for steaming? Is it because stickers will discolor the lumber?
Is the load of lumber left "loose" when it goes into the steamer? or is the load banded with strapping?
Will the pallet the load is sitting on discolor the bottom layer? or do I not use a pallet?
How do you know when the load is properly steamed? internal temperature? MC? Can a load be "over-steamed"?
I also have read where it is best to pre-heat the lumber before it goes to steam. How hot does it need to be, and how is this accomplished if the load is tight-stacked immediately off the mill?
Thanks for the help!
9/24/14       #4: Steaming/stickering questions ...
Gene Wengert-Wood Doc
Why must the lumber be tight-stacked for steaming? Is it because stickers will discolor the lumber? There is a chance that stickers will discolor, but more importantly is that after a few cycles they are likely to be full of cracks, splits, etc.
Is the load of lumber left "loose" when it goes into the steamer? or is the load banded with strapping? Either is ok, but metal banding can corrode or stain and plastic can melt.
Will the pallet the load is sitting on discolor the bottom layer? or do I not use a pallet? Use stickers on the bottom layer.
How do you know when the load is properly steamed? internal temperature? MC? Can a load be "over-steamed"? Experience is the best guide. Time depends on lumber's initial temperature, steam temperature, and so on. The more you steam, the greater the chance of strength loss overall.
I also have read where it is best to pre-heat the lumber before it goes to steam. How hot does it need to be, and how is this accomplished if the load is tight-stacked immediately off the mill? Never heard that this is suggested. The main idea if you do this is to keep it at 100% RH, but I do not see why you need to do this. No operation I have seen does it.
9/25/14       #5: Steaming/stickering questions ...
Brian
I have heard that a person steams the wood to darken the sapwood, is that true and/or are there other reasons as well?
9/25/14       #6: Steaming/stickering questions ...
True for walnut indeed.
9/25/14       #7: Steaming/stickering questions ...
10Goal Member
Thanks Doc
10/5/14       #8: Steaming/stickering questions ...
cabmaker
We used to buy steamed cherry. It was uniform in color but the grain seemed to be very "muddy" in the same way tinting lacquer makes everything seem painted.
Is this common?
What would cause this?
