Sawing and Drying
Subject:
Sycamore logs
10/7/14
Ron Webber Member
I plan to build a small home on a lake and have numerous sycamore trees that I have cut to make room. I would like to use a few as structural members to span the openings to support a loft and vaulted ceiling. Also want to use the smaller curved limbs as hand rails and balusters similar to that in the Yellowstone Lodge. Also can I cut some in half to use as stair treads. I don't want to mill any of them, using whole logs instead. Has anyone had experience using whole sycamore logs? I read comments about how sycamore goes crazy after milling but I didn't see anything concerning whole logs.
10/7/14       #2: Sycamore logs ...
Keith Newton
I don't know where you are, but if you don't do something to dry the wood, and get it hot enough to kill insects, they will be inside destroying it as fast as you are putting it up. At least that is the way it is around here.
You won't know they are in there until next year, when the adult insets chew their way out. Sycamore doesn't have much natural resistance to decay or insects.
