Sawing and Drying
Subject:
air circulation in kiln
10/29/14
Dave Member
I live in NW Ohio. I built a small solar kiln 5 X 10 with 60 SQ. Ft. of greenhouse glazing. 3 1/2 in. of rigid foam insulation in floor and walls. The wood currently loaded is about 240 ft. of maple cut 8/4 X 8 ft. long. I have a fan to circulate the air with a thermostat attached. The wood was air drying outdoors while I built the kiln for about 6 wks. Current outdoor temps are about 50 degrees but that will be a downward spiral soon. When should I be running the fan? Do you think this wood will take all winter to dry?
10/29/14       #2: air circulation in kiln ...
Gene Wengert-Wood Doc
Run the fan when it is sunny or partly sunny and the outside is above freezing. This is general and you can fine tune.
