Sawing and Drying
Subject:
How to cut a diamond shaped panel
1/20/15
Paul V Tabone  Member
Website: http://www.paulvtabone.com
The attached drawing is a front entrance door. We usually cut the 'Diamond ' panels by hand.
Any suggestions or you tube link for jigs for either panel saw or with a cross cut in order to save time? Thanks
Front_Door_Malta.pdf
1/20/15       #2: How to cut a diamond shaped panel ...
I see your drawing as a diamond shaped raised panel, coming to a point in the center, the thickest part of the panel.
If that is correct, the way I have done that is with the wide belt sander and a jig that holds the panel at an angle to the plane of feed. A 60 grit belt is used for sizing, and several passes per facet are required. A fine belt is used on the final passes. A wide (knife) planer can also be used, again with a non level jig or platform to present the panel at the correct angle. A large bandsaw can be used, I imagine, but would terrify me.
I'm thinking about applying to work in Malta. What a wonderful place!
1/21/15       #3: How to cut a diamond shaped panel ...
Keith Newton
If you don't have the large equipment to do as David suggest, you can make a router jig, which would be tapered ramps, with a long base to bridge across to them.
However, I would only use that method to cut in some target depths, then finish cutting the bulk with my big power-plane
