Sawing and Drying
Subject:
milling boards for future jobs
2/10/15
Tim Member
Hi, I go to the saw mill and buy wood for a few different projects at a time, is it ok to mill, ( joint and plane down to a little larger than finished size) the boards that I am going to build with at a later time?
2/10/15       #2: milling boards for future jobs ...
sawya
Of course it is okay. It boils down to how much extra work you want to do - all that work will have to be redone once the boards dry.
2/11/15       #3: milling boards for future jobs ...
Tim Member
when I buy the boards they are already dry. I was just wondering if I milled them down would they stay flat? Thanks Tim
2/16/15       #6: milling boards for future jobs ...
Dennis J Hoover  Member
Website: http://www.terrifictimbers.com
I usually only mill boards down towards finished size for the specific project. Unless I were making only little things. Rough cut out a bit oversize in length, width, thickness and let wood acclimate in the shop or in the same dryness environment that it is going to be used in. When ready to build take it to final size. Wood moves with changes in humidity/temperature, and can also move when milled. A flat 3/4 x 8" board can cup, or a 3 foot board bow or crook, if you quickly mill store-dry to finished sizes, when "store-dry" and "your-final-environment-dry" are not the same.
