Sawing and Drying
Subject:
Timber Frame Barn
5/21/15
Jofussino Member
I'm planning to start a timber frame barn, 36 x 40 feet, four bents, three bays (24 x 40 main barn at 1 1/2 stores with a loft and 12 x 40 lean-to). This will be my first timber frame project. I have never built with large timbers (e.g. 8 x 8). I will only be able to work on this a few days at a time; and with all the joinery, I expect it will take at least 6 to 9 months to get all the timbers ready to assemble. There is a 24 x 36 metal building on site in which I can keep the wood out of the rain and do the joinery; but the building is not heated or air conditioned. My question is: Can I reasonably take 6 to 9 months to cut the housed mortises/tenons/housed dovetails/etc.? I'm worried that over that period of time, wood shrinkage will make earlier joinery not fit their later mated joinery. Would it be less of a problem if I can get kiln-dried 8 x 8 timbers? Does anyone have any suggestions?
6/8/15       #3: Timber Frame Barn ...
James Walker Member
I'm a beginning timber framer too and I've asked the same question at my training sessions. 9 months is definitely too long from start to finish without getting enough shrinkage/warpage to throw off your project.
A couple of suggestions:
1. Depending on the design, you may be able to assemble as you go. Adjacent pieces will have been cut and milled at approximately the same time.
2. Liberally apply an end grain coating to the posts and beams AND then apply it to any additional end grain you create as you cut the joinery - i.e. inside the mortises and housings.
Kiln dried (RF vacuum kiln?) would be ridiculously expensive, especially for a project that's going to be exposed to atmosphere anyway.
hope that helps
