Sawing and Drying
Subject:
milling quartered red oak
7/20/15
andy Member
i was curious on the drying time on
24 inch diameter red oak that was quartered
a year ago and stored in a shed.
i just started to mill some for use and
curious how long will it take for
3/4 and 1 inch slabs to sit in a non kiln
enviroment,basically my garage attic..
thnx
7/26/15       #3: milling quartered red oak ...
olcus  Member
Hey Andy,
Though I don't know the answer to your question, I do know that the Doc and others are going to ask you what part of the country you live in, relative humidity, etc... in order to give you a good answer.
I'm lookin' forward to the answer myself. I have 32 acres of red oak here in southwest Missouri and an HD36 Norwood bandsaw mill. Haven't built my kiln yet, and have some red, white and post oak logs I cut last year liyin' out in the open behind the shop. Sorry for the irrelevancy.
7/26/15       #4: milling quartered red oak ...
Dave Boyt  Member
The quartered logs will take several years to reach air dry (around 14% moisture content) in most parts of the U.S. If you have good air circulation, the 1" boards will take another 2 or 3 months to equalize out, but may still not be kiln dry, depending on conditions. Also beware of bugs, which are especially active just under the bark. Best bet is to get a moisture meter & monitor moisture content.
Olcus, I'm running a Norwood HD36 in Neosho, MO (20 mi south of Joplin). Drop me a line if you over my way! The pottershophollow.com web site has my contact info.
http://pottershophollow.com
7/27/15       #6: milling quartered red oak ...
andy Member
hi
i am in the nyc subs and really was curious on the difference in drying times from a log to a 1/4 log that has sat for a year.
i remove all bark b4 i cut most logs as i try to
keep the blades sharp and wood bug free.
the 1st run of 1 in slabs after 3 weeks in
my garage attic are at 16% mc using my
lignomat meter.im using this for extension window jambs for my house reno.
they will be 3 1/2 in by 60in and 3 1/2 by 37in...will run them thru my planer next week and sand.
7/27/15       #7: milling quartered red oak ...
Dave Boyt  Member
That should work, then. You might loose a bit (maybe 1/64") in width if it dries more after installing, but no change in length.
8/7/15       #8: milling quartered red oak ...
John TenEyck Member
If your jamb extensions are for the inside you want KD lumber; 16% is way too high; you need 10% max, and preferably 8% or less. If it's for exterior jamb extensions red oak is a poor choice. White oak, on the other hand, would be excellent.
John
