Sawing and Drying
Subject:
a random prong test
8/15/15
woodlearner Member
we've had these few hard maple boards that sitting on the wall in the grading station that were planed down s2s so a customer could see how white they are. I decided to cut a prong test out of one just for a random quality test. I cut a foot off the end, then cut the waffer I used off of the fresh end. The result was not well. The prongs came together and slightly past each other. After spending the night in the kiln office the prongs opened to perfect parallel. I have set the test in the main office for a day, on my porch for a day and in my house for a day to see if the prongs would move again ,but they have not.
Can anyone tell me how and why the test went from bad to good, and why it is staying good?
8/16/15       #2: a random prong test ...
RichPall
This should help you understand the prong test.
https://www.extension.purdue.edu/extmedia/FNR/FNR-132.pdf
Rich
8/17/15       #3: a random prong test ...
Gene Wengert-Wood Doc
The prong test requires no moisture gradient. So, what happened was that the surface of the wood had picked up some moisture after drying. This surface then tried to swell slightly, but the core prevented that. When you cut the prongs, the surface could now swell. When you let the prongs sit for a while, the surface moisture left (or the wood on the inside that was very dry picked up moisture). So, now the gradient is gone, and the true stress situation is indicated.
I have seen loads of lumber rejected because of false, gradient related, prong tests.
