Sawing and Drying
Subject:
fan reversals
9/26/15
joel Member
We have our kiln fans set to reverse every 2 hours. i was considering lowering the reversal time during conditioning, My thought is to move steam back and forth across the load more often.
What are others doing? How do other times work?
9/27/15       #2: fan reversals ...
Gene Wengert-Wood Doc
I have never seen or heard of anyone using shorter than two hours reversals.
9/27/15       #3: fan reversals ...
woodlearner
No one ever heard of any one walking on the moon until it was done either......
9/27/15       #4: fan reversals ...
To be clear, my response was an answer to the first question "What do others do?" I should have added that some use six hour reversals with no noticeable difference in stress relief compared to two hour.
9/27/15       #5: fan reversals ...
woodlearner
So basically the only thing that would affect conditioning would be the length of time?
9/27/15       #6: fan reversals ...
Conditioning (relief of stresses) is affected by how fast you can add moisture back and by the temperature used.
So, cooling the lumber prior to conditioning means that when the lumber is subsequently steamed, there will be a lot of condensation initially, so conditioning goes fast.
This also means that higher MC lumber will have less moisture increase, compared to drier lumber, so stress relief for wetter lumber will take longer. This means that uniform final MC will produce better conditioning.
Some kilns are so well insulated that when they use steam spray, the heat in the steam drives the temperature well above desired temperature, so the humidity or EMC is way off, so conditioning is slower.
These are major effects, compared to side to side variations through the load.
Note when suing steam, when the steam condenses, it releases heat, which does heat the lumber's surface briefly to 212 F.
10/4/15       #7: fan reversals ...
Don Lewis
We normally set our fans to reverse every 2 or 3 hours. Shorter reversals create some control problems during conditioning because you want to control on entering air and it takes a few minutes to balance out. The heat problem is more of a problem with steam conditioning so high pressure water spray has become very popular. Solves the heat problem and avoids the problems related to exhausting live steam from a boiler.
