Sawing and Drying
Subject:
to calculate driven pulley size
10/3/15
hussain Member
Can anyone tell me how to calculate the output RPM of a given size pulley? If I had a motor of 1400 RPM with a 28mm shaft with a 9" pulley mounted on the shaft.
10/3/15       #2: to calculate driven pulley size ...
YHGTBKM
The output RPM is 1,400.
Next question.
10/4/15       #3: to calculate driven pulley size ...
Gene Wengert-Wood Doc
The circumference of a pulley is pi x diameter. So, the 9" pulley will have a belt move 3.14 x 9 x 1400 inches per minute.
If the pulley belt on the 9" pulley goes to a 12" diameter pulley (often called a sheave, pronounced "shiv" and not a pulley), then the circumference of the 12" pulley is pi x 12" diameter, which means the path is 25% longer, so the rpm of the 12" pulley is 1050 rpm, or 25% slower.
10/4/15       #4: to calculate driven pulley size ...
EC Aumiller Member
Shaft diameter does not matter...
Input RPM x input diameter = output RPM x output diameter
so with 1400 rpm input and 9" input diameter the output speed will be...
(1400 x 9) divided by the output diameter or 12600 divided by output diameter...
in Mr Wengert's example of 12" it would be 12600 / 12 = 1050 RPM
for a 6" pulley it would be 12600/6 = 2100 RPM
10/4/15       #5: to calculate driven pulley size ...
EC Aumiller Member
To calculate driven pulley size...
For a motor at 1400 RPM and 9" Pulley, take 12600 and divide by your desired RPM to get the driven pulley size in inches...
