Sawing and Drying
Subject:
RE: Bandsaw Blade Life
10/9/15
Tommy
How many times can you sharpen a blade before you get a crack in it, when cutting Northeast hardwoods? Our blade is 19’6” long, 1 ½” wide, .055 thick, and 7/8 inch tooth spacing.
In other words, what is the normal usage one could expect from a carbon steel (not bi-metal) blade with the above specs cutting Northeast hardwood logs that are on average 12 to 24 inches in diameter?
Also, what would be the manufacturer and specific blade recommended for this type of durable cutting?
Thanks for your help.
10/11/15       #2: RE: Bandsaw Blade Life ...
Per-Olov Member
I have experience from "Munkfors" blades. When I starts to use a new blade I "connects" a note card to the blade as will follow that blade over its life. All actions like sharpening, set adjustments, how the blade behaves in the wood is noted on the card.
I have resharped one blade 28 times. It was used for pine and spruce logs, about 15 feet long and 12- 15" diameter. That blade went broken after that I had cut about 100 logs, mostly to 2" thick boards.
You have to be careful to not burn the steel and take very light cut, all the way down in the gullet, when you resharpen the blades.
I never run a blade longer than 1- 1,5 hour, then I resharpes it and if needed adjusts the set. If you can have cutting liquid to keep the steel coolest possibly when you resharpes, I think you can add some life to the blade.
10/11/15       #3: RE: Bandsaw Blade Life ...
Tennessee Tim
Tommy,
Your thickness on your blades may be your problem for premature failure....depending on your bandwheel size...I think a minimum approx 26" is what I've read before...a 19" "bends the blade too much and the extreme flexing is tough on metal.
Next can be correct blade tension...every distributor has differ specs. I run 2 differ brands and I have to watch the specs.
3rd (and I have this problem) running a blade TOO long and damages due to more pressure exerted to the blade as it gets duller.
NEXT: I went to Cooks sawmills and Tim has written great articles on fine tuning your bandhead set-up. It's done miracles to saws performance!!! My next change is to add their adjustable bandguides and felt lubing system.
I hope this helps.
Have a Blessed and Prosperous day in Jesus's Awesome Love....Tim
10/20/15       #4: RE: Bandsaw Blade Life ...
Dave Boyt  Member
Watch for cracks in the gullet before sharpening. A blade break at the weld is a manufacturing defect, and you can often get a batch of blades with the same defect. As Tennessee wrote, a thinner blade will be less prone to fatigue. The wood you cut will have little or no effect on the fatigue of the blade. I'm running 1-1/4" .045 blades on a 19" bandwheel and get 7-10 sharpenings. When the blade is down to 1-1/8", I discard it, since it dulls quickly once you get past the heat treated zone on the tip. As Per-Olav mentioned, when you sharpen the blades yourself, you tend to be a lot more particular about changing them at the first sign of dullness, so they just need a touch-up instead of a serious sharpening.
