Sawing and Drying
Subject:
Huge quartersawn oak problem
3/14/16
Desperate Dominique Member
We are a high-end european furniture producer which is working only in complete solid furniture.
However we have a huge problem at this moment.
Since All of our timber is Rift/quarter sawn.
If we are glueing a table we usually have around 2 out of 10 planks with ray flakes.
The problem we are having with these ray flakes is that after applying the stain, sometimes it is happening that 1 of the flakes is chipping And it looks like a crack on the outside. While it's only the ray flake.
All of our timber is rift sawn. and we are drying it ourself in our kiln.
All the time we are trying to dry it as slow as possible and in our kiln we are never drying more then 2% / day, on average it's approximatly 0,85-1% / day in the kiln.
Usually our timber is around 35-40% when it's going in the kiln.
How does this come? What can we do to avoid it?
Because at this moment we can throw away 1 out of 3 topplates we are making...
and last weekend this happend for the 70th time in the past 6 months. So this is very frustrating and very costly for us.
3/15/16       #2: Huge quartersawn oak problem ...
Ray Flake
Medullary rays in oak are sometimes referred to as "ray fleck". Flake is something else.
Structurally, they are of a very different makeup than the tubes that make up the bulk of the tree - for one thing, they run from the center of the tree radially out to the bark.
Didn't you get good answers last time you posed this question?
If failure continues perhaps it is time to consider another field of endeavor.
3/16/16       #3: Huge quartersawn oak problem ...
Steve
Or a different supplier of wood? Might it be a drying problem?
3/16/16       #4: Huge quartersawn oak problem ...
GeneWengert-Wood Doc
This is likely a machining problem and is not related to drying, although over drying can make it worse. It is called chipped grain.
3/18/16       #5: Huge quartersawn oak problem ...
GeneWengert-WoodDoc
I saw a picture of this defect and it is surface checking.
