Sawing and Drying
Subject:
Cool down times????
4/12/16
PA Lumber dryer
Website: http://www.masco.com
I am a kiln operator for a cabinet manufacturer in PA. Currently it seems there has been a question as to if we are leaving the kiln to "cool down" long enough after conditioning. So after many hours spent trying to research this I have came up empty handed. So I am asking other kiln operaters out there, how long is good for the "cool down"?
4/15/16       #3: Cool down times???? ...
Gene Wengert-WoodDoc
I wonder why the Dry Kiln Operators' Manual, Drying Eastern Harwood Lumber and Drying Hardwood Lumber do not mention a cool down cycle.
At the end of the stress relief cycle (conditioning), there is surface moisture, so the lumber cannot be utilized until this moisture dissipates...a few days. But this happens in or out of the kiln.
In my travels, I see most kilns unloaded soon after the end of conditioning.
4/15/16       #4: Cool down times???? ...
PA Lumber dryer
So does that mean that the prongs shouldn't be tested until a few days after conditioning? We have most always given the kiln anywhere from 2 hours to 12+ hours after conditioning to test the prongs.
4/15/16       #5: Cool down times???? ...
Scott Weikert
What problem are you trying to correct by letting the kiln cool down? Your prong test should be straight when it is cooled down. If it is straight while hot it will probably close (at least partially) within a day or 2 showing that there is stress in the lumber. If you have stress, you need to condition longer.
4/15/16       #6: Cool down times???? ...
Your question is a good one. The prong tests require NO MOISTURE GRADIENT in the piece of lumber being tested. But we know that the high humidity conditioning cycle will leave the shell with a higher MC than the core. So, prong tests immediately after conditioning will be in error.
What can we do? You can wait a few days to cut the prongs, hoping that the gradient is gone by then...certainly 12 hours is too short for the gradient to be gone. The best option is to cut the prongs as soon after conditioning as possible and then put one ro two prongs into microwave oven for 15 seconds (maybe 30 seconds with mist spray). This heat will move the moisture enough so that in another few minutes you will have accurate results. With a "no stress" indication, you can immediately unload the kiln, but if you still have stress (which is rare for air dried lumber as there is so little stress) you can immediately add a few hours to the conditioning cycle, as the wood and kiln have not cooled off yet.
This procedure is in DRYING HARDWOOD LUMBER.
OK?
4/15/16       #7: Cool down times???? ...
PA Lumber dryer
The problem that we are seeing is that when cutting the prongs we see no stress and then release the kiln. Well as luck my have it somehow stresses end up back in the lumber after it has been released. We are all pretty stumped and the question has been raised about how long the kiln should sit to cool down before either prongs are cut or kiln is unloaded
4/15/16       #8: Cool down times???? ...
The problem you are having with stresses (the prongs look good and then later do not) is due to moisture gradients. Use a microwave.
Incidentally, if you are not getting rid of the stress, it is likely that you do not get humid enough right away.
Does your steam have heat that drives the dry bulb up so that the depression or EMC at the start of conditioning is incorrect (too large)? This is a common reason why stresses cannot be removed.
Although it is self-serving, it sounds like you could use a one day consultant visit.
4/18/16       #9: Cool down times???? ...
Just to be clear, the prong tests are valid only if there is no moisture content gradient in the lumber.
