Sawing and Drying
Subject:
why is my butternut sapwood really hard & dark
5/26/16
Jason Pollock Member
This limb I have cut into out of a walnut tree in my yard ,I assume is butternut, I can't find a description of wood that matches it the heartwood is soft like balsa but the sap wood is really hard and dark. Is this common?
View higher quality, full size image (3256 X 1836)
View higher quality, full size image (3264 X 1840)
5/26/16       #2: why is my butternut sapwood really ...
farwode
That is some very attractive firewood you have there.
5/26/16       #3: why is my butternut sapwood really ...
TennesseeTim
Website: http://tsmfarms.com
Firewood????? LOL!!! People pay premium for spalting like that!!!
Butternut I'm not sure of BUT the light soft wood is due to the heart is in the 3rd stage of spalting....which is beginning of rot. With the pics it appears the tree was dying from center out (how most hollow trees start). You actually caught it at the correct stage and able to get a few beautiful boards. I let woo/logs lay around for years to achieve what you accidently gained. The dark wood does appear to be walnut/ butternut. BEAUTIFUL!!!!
Check out my website under sub title "New and Hot off the Mill" @ www.tsmfarms.com
5/26/16       #4: why is my butternut sapwood really ...
Hold on, are you joking? Can't tell from the way you type. But you are asking if you can get butternut out of a walnut tree? It's rotten in the center of a walnut branch, that's all. Hope I'm just not playing along with the joke, or even worse, now I will be the joke.
5/26/16       #5: why is my butternut sapwood really ...
TennesseeTim
I guess the joke is on you since you spoke it. Yes butternut is a form of walnut...some call it light walnut. I've seen dk walnut be light in color and one of the butternuts I sawed was a darker color and if I hadn't cut the tree standing seeing he bark and tree as a whole I would've guessed it as walnut. I'm sure the trained eye that handles it everyday can see the difference immediately as with pecan and hickory are usually graded together also chestnut oak and white oak...they look similar but have nothing in common in rot resistance (chestnut oak is open cell).
Rot....your correct....that's what true spalt is at 3rd stage....the black lines are a battle of ??? and ??? in the second stage.... the late end of third stage (if allowed to go that far) is rot of none usable. Spalting is stopped at which ever stage it's at once dry and won't go any further.
I hope that info helps you.
5/26/16       #6: why is my butternut sapwood really ...
TennesseeTim
Error....I meant it's also called white walnut.
5/27/16       #7: why is my butternut sapwood really ...
woody fire
Given how small the pieces are, plus the extensive rot, it's minimally acceptable as firewood.
I would toss it in the burn pile and look for some non-rotten wood to spend my energy on.
5/27/16       #8: why is my butternut sapwood really ...
Gene2Wengert-WoodDoc
When wood is first harvested, the sapwood contains many sugars. These sugars are attractive to various fungi, that are grey or blue in color. The heartwood does not have food for them so they avoid the heartwood. These fungi invade the wood in a few days to weeks.
However, other fungi do like the heartwood as these fungi are eating the basic components of wood...the lignin, which is the stiffener and glue that holds the cells together. These fungi prefer dead trees and take months to develop, so during that time, the sapwood is drying and Getting "hard" while the heartwood is beginning to soften and is still quite wet.
5/27/16       #9: why is my butternut sapwood really ...
TennesseeTim
This is a google search on spalted butternut for the one(s) who say it's firewood. Jason, I can't tell the sizes you have but there's a few tables or if smaller there's a few beautiful jewelry boxes. Spalting is a specialty wood and a lot of people have no idea how to build or use it so they say "throw it in the fire". It does require more time but the rewards are worth it.
Search - Spalted Butternut
5/27/16       #10: why is my butternut sapwood really ...
woody fire
You assume much when you attempt to refute a comment I made, one which is based on decades of experience.
I know that you think that wood has value, but the line between spalted and rotten, once crossed, has rendered the wood useless.
Or, better yet, just try to sell it and see how the market responds - that is a sometimes useful gauge on just what raw/rotten materials are worth.
I produce a lot of products from spalted wood and was merely trying to save someone from investing time and effort in wood that is, at this point, merely a diminishing source of BTUs.
Have at it - it's your life and time, but if the end product turns out to be a piece of rotten garbage, well, what can I say?
5/27/16       #11: why is my butternut sapwood really ...
This piece is just part of a branch that fell off in a storm I have more of it that would be larger and better quality, the worm holes and rot could probably be similar to knotty pine in cases where I have glued the two pieces together the centre third where white is also hard and free from decay so two thirds of the other wood I have is good either way, But why is the sapwood so hard is this normal other wood has soft weaker sap wood this is the reason I can't find a description to identify it properly .
The pieces I have I am going to cut two pieces into the ends of the board so the sapwood is a frame and the soft heart wood will be carved to hold rings in place ,maybe a little flocking.
5/29/16       #12: why is my butternut sapwood really ...
The heartwood is soft due to decay. The sapwood appears hard because it is dry. Further, we do know that not all basswood is soft. A wood carver can tell you, from experience, that some basswood is quite hard and difficult to cut. So, not all basswood is the same.
5/29/16       #13: why is my butternut sapwood really ...
Tennessee Tim  Member
Did I miss something Gene....Basswood ??? or did you mean butternut which is considered soft but sometimes hard???
5/29/16       #14: why is my butternut sapwood really ...
Gene Wengert-WoodDoc
Indeed, I did mean butternut. It is true for basswood too.
5/31/16       #15: why is my butternut sapwood really ...
We have had a change in weather here in Australia and the other small boards I have cut seem to have adjusted an the difference between the sap wood and heart wood seems to have evened out there is less rot in these boards it's a really nice texture ,although the sap wood does still seem harder than the heart wood o have assumed it is just from the spalting then I wonder if the dense woods I have would have done the same for eg. The gidgee lengths I have which have a white layer of sapwood over the dark marbled and ringed heartwood which is incredible hard the sap wood would then become harder then the wood is ATM it could be nearly then considered stone. I would love to cut some of this.
5/31/16       #16: why is my butternut sapwood really ...
Jackson Pollack
What?
5/31/16       #17: why is my butternut sapwood really ...
We know that sapwood cells die almost immediately after they are formed. We know that heartwood cells were sapwood cells earlier in their life. We know that wood is basically made of two chemicals...cellulose which is cotton and lignin which is the glue and stiffener. The amount of these chemicals in a cell does not change unless we remove part of the cell wall by insects or decay or chemical dissolving. We know we cannot strengthen wood except through drying and by adding a chemical into the cell or cell wall. For softwoods, we know that slower growth rate is slightly stronger. For most hardwoods, rate does not affect density or strength. The exception is ring porous, like oak and ash, where slower growth is weaker.
