Sawing and Drying
Subject:
Drying shed
2/9/17
R.K.
I need someone else thought on this beside my own! what is best way orient drying shed? Option #1 so that prevailing wind hits broad side? or #2 so prevailing wind goes down long side? Both sides open lumber loaded from both sides
Many Thanks
R.K.
2/9/17       #2: Drying shed ...
Gene Wengert-WoodDoc
It depends where you are located. If in an area with snow, face the shed opening to the south so you get snow melting at the door which allows easy access at any time.
Otherwise, any orientation is fine as you can use Shade-dri to block excessive wind, installed like a shower curtain, so that at low MCs you can open the curtains. Exact operation depends on species and thickness.
The width of the shed is critical. Again, depends on species and thickness.
2/9/17       #3: Drying shed ...
R.K.
I am going to build a "t" type shed and I am using the info. from the article you did for Sawmill and wood lot on air drying sheds for design features. Many thanks for the quick reply!
R.K.
