Sawing and Drying
Subject:
Drying Cypress
3/12/17
Bill Stuewe  Member
Website: http://www.billstuewe.com
Gene,
A major flood took down a large number of cypress tress near Wimberly Tx a few years ago and a man is bringing me about 20 logs to saw that are about 30"d x 7'long. He wants me to saw , dry and then process at least some of the wood into flooring for him. I have an old Nyle L200 in a 40' refer container. I mainly use it to bug kill and the controller goes erratic when the heat gets over about 150° I have a vent fan that I can set to vent at a set temperature. How fast can I dry this wood? What settings should I use? I do not have wet bulb/dry bulb or humidity controls or a way to add steam. Just a box with the Nyle and 7 fans plus a louvered vent fan. The only thing I have dried with this kiln is mesquite. I normally air dry and use my solar kiln for kiln drying.
3/13/17       #3: Drying Cypress ...
Don Lewis
start at 120F, no higher and don't go higher than that until the wood is dry. The other setting depends on the model L200 so call Nyle.
3/15/17       #4: Drying Cypress ...
Gene Wengert - WoodDoc
It is suggested that this wood be dried quite slowly or else it will crack. Final MC is around 7% for flooring but this makes this species of wood brittle with machining defects that you will get blamed for. I can see some serious issues possible.
