Sawing and Drying
Subject:
low humidity
3/23/17
J Member
I'm having issues keeping my relative humidity and wet bulb settings in my DH kiln. I have dried a couple of loads since building the kiln, without issue, but this is my first load of 8/4 air dried lumber. The load had an average of 19% when it was loaded. I have a current loss of about half a percent a day on my test boards. The issue is that I am unable to maintain the wet bulb temperature and the humidity inside the kiln reads 20%, on the kiln side, under the baffle. My dry bulb settting is 120F and the wet bulb is set to 98F. My relative humidity should be roughly 44% - 45%. I understand that since my wet bulb reads on average 88F that the humidity is going to be lower than the target area. The wick is new and saturated, with a full bottle of filtered water. My question is what can be done to raise the wet bulb and humidity inside my kiln? Also will a low humidity such as 20% cause damage to the lumber, even though it is scheduled to shut down at 7%? Any help would be greatly appreciated
3/24/17       #2: low humidity ...
Gene Wengert-WoodDoc
The first tHing to do is to compare the DB and the WB readings when the WB has no wick and is dry and no water is slashing on it. Try covering the water with plastic bag. The two readings should be identical.
What is causing your DH compressor to run? If you want higher RH, do not run the compressor until you get the desired RH.
